I am interesting in evaluating the CYPD3120 in a DisplayPort application.I've noticed there is a reference design called "EZ-PD™ CCG3 USB-C to DisplayPort Cable Solution"
Link: https://www.infineon.com/cms/
Unfortunately, the PCB is not for sale...
I was wondering if I can get the PCB Geber files in order for manufacture it by myself.
Another Question - Just making sure I understand: Is the CYPD3120 is pre-programmed in this application or should I need to upload a specific firmware in order to operate it in the above application?
Thanks!
Nir
Please find attached the Gerber files.
Let me know if you need anything else.
Abhilash P
Please find below the default factory firmware configurations for different CCG3 parts,
Regarding the gerber files, I will get back to you.
Abhilash P
The attached zip only contains the electric schematic (I already have them..), not the requested gerber files (pcb production files)
Can you please check again?
Nir
This is perfect, Just what I needed!
You've been a great help
