USB EZ-PD™ Type-C Forum Discussions
PoPr_2735541
First like given
I tried looking through the datasheet and documentation for the EVK, but couldn't find any information. What is the current limit for the 3.3V output on the BCR evaluation kit? (Pin V3P3 on J1 and "3.3V Output from BCR")
Thank you
PranavaYN
500 replies posted 250 solutions authored 50 likes received
"V3P3 pin on J1" and "3.3V Output from BCR" are connected to VDDD pin output of the BCR chip. This pin should just be used as a test point to measure VDDD voltage. It should not be used to power any external load. Therefore current limit for this output is not relevant.
Pranava
Pranava
PranavaYN
Pranava
Pranava
