USB EZ-PD™ Type-C Forum Discussions
TeIk_3653391
10 replies posted 10 sign-ins 5 replies posted
Our firmware is monitoring a fault gpio line from a load switch that is asserted when a connected device is faulting and pulling too much current. If fault condition does not clear within certain time I call app_disable_pd_port() to disable further activity on the port.
After a delay and when the fault flag has cleared I want to enable the port again. What is the correct way to do this? There is no symmetric API call to enable the port.
We're using CYPD5225-96BZXI. Source mode only.
PranavaYN
500 replies posted 250 solutions authored 50 likes received
You can call dpm_init and dpm_start functions to re-enable the port.
Pranava
PranavaYN
Pranava
Thank you, we'll try something like this.
ccg_status_t app_enable_pd_port(uint8_t port)
    ccg_status_t retval = CCG_STAT_SUCCESS;
    if(dpm_init(port, app_get_callback_ptr(port)) == CCG_STAT_SUCCESS) {
        retval = dpm_start(port);
    return retval;
