Hello
I would like to detect the connection/disconnection status with the HOST device and output a (GPIO) signal to the external EC.
In details, Specifically, when the PDO contract is made, the BCR notifies the external EC with a GPIO signal (Hi or Lo)
When the host is disconnected, the BCR notifies the external EC with a GPIO signal (Hi or Lo)
Q1) Is it possible to use BCR to output the above detection signal to an external EC via GPIO, etc.? Which pin can I use if possible?
Q2) Tell me about the usage of "Pin 8 GPIO_1". Is it possible to use the above detection signal?
Best Regards
Q1) No, Unfortunately the GPIO doesn't have event trigger functionality, the output can change by HPI from host controller of BCR.
Q2) The pin can be used as just GPIO expander of host controller. It can not be used as you expected.
Could you tell me the background why you want such signal source?
