USB EZ-PD™ Type-C Forum Discussions
BhargavGolla
Hi community ,
                I am using CCg3PA in my project, is there a way to read D+ /D- line status  or voltage from we as source and DUT as sink. Is there a specific function for this requirement.
thanks
HmdRahmathulla
Moderator 25 replies posted 25 sign-ins 5 solutions authored
Hi BhargavGolla,
 Thank you creating case in infineon community.
 chgb_dp_status(portnumber) is the function to check the states of D+ line
 chgb_dm_status(portnumber) is the function to check the states of D+ line
if it is High, return will be True, otherwise it will be low.
Mohamed Rahmathulla
HmdRahmathulla
Hi BhargavGolla,
Mohamed Rahmathulla
BhargavGolla
Hi Mohamed Rahmathulla,
     Thankyou for the reply, But there was no such function as 'chgb_dp_status' in Api guide or the reference code i downloaded from website,  can you provide more  information about that specific function in detail.
Thankyou.
HmdRahmathulla
Hi BhargavGolla,
 You can find this function in Power SDK which will get it in below mentioned site.
 https://softwaretools.infineon.com/tools/com.ifx.tb.tool.ezpdpowersdk
please do check in pdss_mx_hal.c file for respective api.
Thanks  & Regards
Mohamed Rahmathulla
