USB EZ-PD™ Type-C Forum Discussions
Raro_2284361
First like received
So we are testing a lot of devices and have made some simple Power Roll (PR swap) requests and it seems different devices respond differently to the same code
Most Samsung Phones work, LG and MOTO phones do not work, Apple devices do not, HP devices work and so on
Our Design is based around CCG3 3171, used as a DRP for a USB HUB UFP port, we are requesting PR swap from connected devices that Require a Sink Connection prior to a SRC connection.
Any and All Help Greatly Appreciated
HirotakaT_91
As with CCG3 which can set Default port role, DRP prefered role, and Port role, smart phone devices are also implemented some chips and which can act as DFP or UFP. The behavior depends on the implementation of each smartphone device.
Hirotaka Takayama
Yes, that is correct most type C PD phones/pads have capability as a Host or Device , the question is how to force an OTG switch of data transfer by setting connected mobile device (phone or pad) so that external devices can be enumerated
As our testing results of dozens of devices show there is many ways to accomplish this task, for instance Samsung S8/9 requires a sink connection to enumerate device and than a PR swap can be sent to charge at the same time as transferring data this however does not apply to Samsung A1 8 inch pad does not accept a PR swap from CCG3 it does accept a PR swap from TI/VIA/Richtek and many other ICs we have tested ... so yes the issue is specific to CCG3 code and the list of incompatible devices is growing daily as we are doing more test
Our Request was to get help with proper implementation and evaluation of Port Roll as to possible issue a DR swap when devices are connected to CCG3 and sourcing power from CCG3
Sent from Rads iPhone
We have tried a few things that we think may be interfering :
Disabled Alt mode support (since we are using Cypd3171 no billboard anyways)
We tried Sink and source PDOs to be identical in power levels so we can issue a PR swap
We tried charging default port roll in configuration utility
No success
Please help its still an open issue
RajathB_01
250 replies posted 100 replies posted 50 replies posted
Hi Rad,
Can you clarify me on how you are using CCG3 (CYPD312x) and/or CCG3PA (CYPD317x).
There is no CCG3 3171, are you referring to CCG3PA 3171?
But in the case of a standard CCG3PA 3171 design, there is no datapath, so please provide information on how you have customized the data interface.
Rajath
RajathB_01
Rad,
Can you also attach CC logs of failed connection?
Rajath
Sorry to cause you so much confusion as far as I'm aware there is only one 3171 ic in the entire Cypress CCG family and yes it is CCG3PA
Would you like reports using Cypress PD sniffer or Total Phase sniffer?
Cypress PD sniffer.
Thanks for clarifying. I am not too confused, but since this is an open community, we strive to make things clear for all levels of users
Rajath
Please accept my apologies for my Rude behavior
I will post sniffer results tomorrow
Hi Rad,
Is there any update about this threads?
Lisa
