YoIs_1298666
Level 5
Level 5
250 sign-ins 100 replies posted 100 sign-ins
When changing the voltage of type-C, what signal is used to control from CYPD3171 to SC8802?
Yocchi
MallikaK_22
50 likes received 750 replies posted 250 solutions authored
SC8802 is the bidrectional buck-boost regulator connected to the USB Type-C port.
For CYPD3171 (Power Bank application) this part receives power from VBUS input and it controls the power supplied to the battery.
The control signals are as follows:
>>PWM_I- Current setting for SC8802
>>EN - Enable SC8802
>>FB- Voltage regulation feedback pin, directly connected.
You can refer to the CCG3PA Evaluation Kit Guide for the schematics and description http://https://www.cypress.com/documentation/development-kitsboards/cy4532-ez-pd-ccg3pa-evaluation-k...
Mallika
MallikaK_22
>>EN - Enable SC8802
Mallika
There is one more control signal:
>>DIR- It controls the charging and discharging direction control for SC8802.
Mallika
Hello Mallika-san,
Thank you very much for your reply.
From SC8802 datasheet, I can understand what you say.
I checked the schematics in case of PA(Power Adapter) and observed the signals.
[In case of PA (Power Adapter)]  from SC8802QDER
DIR:   8802_DIR <- J9-1 <- J9-2 <- AXRES_P2.0 <- J10-15 || J11-15 <- CCG3PA_AXRES_P2.0 <- AXRES/P2.0
          "High level with pull-up resistor:4.6V"
EN:     8802_EN <- J10-8                                                   || J11-8 <- P1.1
          "Low level with pull-up resistor:0V"
PWM: SC8802_PWM_V <- J11-20                                       || No connection
          "High level because of pull-up resistor:4.2V"
IPWM:8802_PWM_I <- J10-12                                           || J11-12 <- P1.0
          "approximately 4.5V with pull-up resistor"
FB1:   FB1_88 <- 8802_FB <- J10-7                                   || J11-7 <- FB
          A pulse occurs when we change the voltage.
          for example
          1. from "5000mV, 3000mA" to "12000mV, 1000mA"
          2. from "12000mV, 1000mA" to "5000mV, 3000mA"
Can the SC8802 set the voltage only with this?
Yocchi
Yes, this much (EN,DIR,PWM,IPWM,FB) should be enough for SC8802.
You can refer to the schematics for better understanding.
Mallika
