JoLo_4180566
Up until today, I've been able to program firmware onto my CCG3A through CC line as well as the Miniprog3. All of a sudden, I am getting the following error:
Program Finished at 11:39:04 AM                                |
        | FAILED! Timeout of SROM polling. Lost communication with chip.
        | Please, check the following items:
        |  - the connection between the programmer and the PSoC;
        |  - the correct programming protocol is selected;
        |  - the correct connector option is selected.
I've checked all the settings but have not had any luck. I also tried the suggestion in the FAQ regarding reprogramming the CC bootloader but with the same results. Has anyone else had this problem? Did I somehow brick my main board?
JoLo_4180566
I was finally able to program again. I don't know what caused it to not work as I didn't really change anything. It could be that I have a bad connection.
JoLo_4180566
