JuIn_1625121
100 sign-ins First solution authored 100 replies posted
Can the CCG3PA be dynamically controlled and monitored by other MCUs using I2C?
I am aware that I can do this by using the SDK to create the appropriate firmware, is that correct?
Inoue
ShifangZ_26
10 likes given 250 sign-ins 1000 replies posted
Hi Inoue,
1. CCG3PA can be dynamically controlled and monitored by other MCUs using I2C. But this needs firmware customize as per CCG3PA SDK example firmware. [HIGHLIGHT] The default CCG3PA firmware or SDK firmware cannot support this case,
2. You are absolutely correct.
Lisa
ShifangZ_26
Hi Inoue,
Lisa
