The three reference designs for Display Port Cable Solutions show the USB 2.0 signals (D+/-) terminating in the Cypress CCGx or Billboard controller.
Can those USB 2.0 signals be brought out along side the Display Port Signals?
CCG1 Ref: https://www.cypress.com/documentation/reference-designs/ccg1-usb-type-c-displayport-cable-solution
It appears, using the Hub Controller, HX3PD, both the Display port signals and the USB 2.0 signals can pass though.
Is that a special feature only available with he hub controllers and not the CCGx?
HX3PD Ref: https://www.cypress.com/products/ez-usb-hx3pd-usb-31-gen-2-hub-power-delivery
Greg
- display port
- usb 2.0
Hi Greg,
HX3PD also follow Type-C Power Delivery Spec and DisplayPort Alternate mode over Type-C SPEC. The DisplayPort signals never go through USB2.0 DP and DM signals. The USB2.0 HUB inside of HX3PD is for USB2.0 routing, you can see, there are 7 down-streaming ports on HX3PD.
Lisa
