Hi This is Minseon From Korea.
As you can see the title, I wanna get a source code for CYPD3120-40LQXI operates as a Sink adapter.
Can I get a source code in this community?
I guess it would be work to change to hpd pin's direction, but it don't work.
So, I wanna find a core source or key of the role swapping.
Maybe hpd_receive_init related to this problem?
The person who know about this problem, comment me anything.
Thank you very much.
Hello, Lisa.
Thanks to your support,
3. I am looking for the DP to C firmware code for CCG3 CYPD3120-40LQXI. However, as far as I know, the role cannot be changed in CYPD3120-40LQXI Dp dongle design.
We did the following experiment.
DP Source Desktop - Electrical DP Cable - DP receptacle to C Plug Adapters (e.g. Design dp Dongle Project Source Code) - USB Type C alt Mode receptacle monitor
And the monitor cannot detect the signal.
Can I get binary firmware for CCG3 DP receptacle on C plug adapter(C receptacle) from local FAE? I don't buy through local FAE or distributor. If you give me your FAE email address or contact number, I will talk to her/him.
Thank you.
Minseon
Hello Minseon,
CYPD3120's firmware is supporting by CCGx SDK3.0.1, you could install the SDK and customize firmware for your project directly. By default, CYPD3120 example code demonstrate Power Sink and DisplayPort Sink. Which is meaning of HPD signal on CYPD3120 is input by default. And this is following DisplayPort Alternate Mode Over Type-C specification.
Download link: https://www.infineon.com/cms/en/design-support/tools/tools-archive/usb-ez-pd-host-sdk-archives/
If you would like to change DisplayPort Role, there are one page knowledge for DisplayPort Role change from Source to SINK. Sink to Source is similar process. https://community.infineon.com/t5/Resource-Library/CONFIG-CCGx-FIRMWARE-FOR-DISPLAYPORT-SOURCE-AND-S...
Lisa
Hi ShifangZ-26.
I'm writing again because I think what I said was misrepresented.
Does it mean that the Sink adapter that works in Display Altmode can be implemented as the example you mentioned?
I need a source code that works in Display Altmode 1.x.
I will try it with the power adapter source that you told me.
If you don't understand the story, please reply.
Hello Minseon,
Typically, Type-C Port separate Power and Data Role, since Type-C port could work as Power Source or Sink on Power Role, and DFP or UFP on data (USB as example), Based on Video stream orientation, DisplayPort Source could be DFP_D/U, DisplayPort Sink could be UFP_D/U.
You are absolutely getting firmware project of CYPD3120, and the example project is based on hardware of the link. Block diagram is below for your reference. https://www.infineon.com/cms/en/product/evaluation-boards/vd_usb_ccg3_displayport/?utm_source=cypres...
If you have any concerns, feel free to let us know.
Lisa
Hi Lisa
I already set the hardware like a following block diagram.
However, I would like to ask if this hardware configuration and software configuration can also function with the sink device.
For example, a sink device is a TV and a monitor.
I thought it was not working because of the source firmware.
I read the contents following on the link page you gave me.
Is it right to erase all sources related to DFP and leave only UFP?
If you follow the content,
there are many functions that do not work, and it is questionable whether they function properly.
I use pSoC creator 3.3.
I look forward to hearing from you.
Thank you so much.
Hello Minseon,
Could you please let me know details specifications over Type-C of your design?
1)Power: Source or Sink?
List Source PDOs or Sink PDOs if assured above power role.
2)Data:DisplayPort Source or Sink?
List DisplayPort Pin assignment if confirmed above data role.
Lisa
Hi, Lisa
In addition, I ask you somthing Monitor USB-Type-C configurations.
If monitor(sink, Rx) has Role of USB Type C Data, can work Display alt mode scenario 5B?
Our Sink monitor is USB Type C data mode.
Thanks to your support and everything.
From Minseon
Hi Lisa,
Thanks to your support.
1) This figure show that a concepts what we want to do.
Also, We refer to DisplayPort altmode 2.0(or low) standard scenario 5B.
Thank you so much.
Hello Minseon,
As per DisplayPort Alternate mode over Type-C, C to DP cable/dongle (Same hardware as C to DP dongle you refer to) is bi-directional and pin assignment E only. And you could get firmware binaries from local FAE directly which is covering Type-C to DP and DP to Type-C.
If you need separate solution, please refer CCG6SF for DP to C and CCG3 CYPD3120 for C to DP.
Lisa
Hello Minseon,
CCG3 is bi-directional and pin assignment E for UFP_D and DFP_U.
Lisa
Hi lisa.
I understand what you means its 'Role' UFP is UFP_D
Is CCG6SF work on UFP_U/DFP_D?
could you have an other example circuits of firmware?
Hello Minseon,
1. The CCG3 datasheet is default firmware implementations. CCG3 C to DP cable/adapter have implemented indirections for Data Role, Both UFP and DFP.
2. The firmware of CCG3 indirections could be got it from local Infineon FAE or Distributor directly.
3. For DP Alternate mode support, DP2.1 is under development.
4. It seems you are looking for bidirectional C to DP design, CCG3 C to DP or CCG2 C to DP could be referred to.
Lisa
Hello, Lisa.
Thank you.
Minseon
Hello Minseon,
Infineon Distributor could be found from the link. You could get contact E-mail after selecting your location.
https://www.infineon.com/cms/en/product/promopages/where-to-buy/
Lisa
