Hi,all
I just learned this chip. Can CYPM1311 be used as i2c slave device (similar to EEPROM CAT24C32) and controlled by another main control chip? If so, what is the i2c slave address of this chip? I can't find the corresponding description in the Datasheet.
Or is there something wrong with my understanding? Please correct me!
Thanks & Regards
Jiong
Hi Jiong,
Thank you for posting in infineon community.
I2C slave address is user configurable. you can configure in modus toolbox itself.
the highlighted one is to set the slave address. you can also get sample program named I2C Slave LED in project creator tool under PMG1 BSPs.
Thanks & Regards
Mohamed Rahmathulla
Hi Jiong,
Thanks & Regards
Mohamed Rahmathulla
