I am looking for the tool to configure the device CYPD5225.
I have downloaded the software PSoC Creator 4.4, but i was not able to find the component CYPD5225 in this tool !
What is the tool to configure the registers on the CYPD5225 ?
What is the tool to generate the HEX file mention in the document "CCGx (CYPDxxxx) Programming Specifications" Document Number: 002-22328 Rev. *G ?
I have the tool to download the HEX file to the CYPD5225 device but not the tool to generate the HEX file.
Thank you for help,
td83
- cypd5225
Hello td83,
1. You can select read from firmware file to get configurations of the binaries, and then review/change the configurations via Ez-PD configuration Utility. But, you need a .hex or .cyacd file which is matching the hardware design you are working on.
2. You could get .hex/.cyacd from the folder if you have been installed any SDK or Kit from www.cypress.com.
For example, CCG5 hex files:
...(installed path)\Cypress\EZ-PD CCGx Host SDK\CCGx\Firmware\binaries
3. If your hardware design is not match our reference design/Applications hardware on Datasheet, you have to generated .hex/.cyacd files by PSoC Creator based on example codes have been offered in SDK. And Ez-PD configuration Utility will generated .c file for your project and then you could replace config.c in PSoC Creator directly.
Lisa
