I am using a power delivery CYPD5225 with a Tigerlake SoC.
Look with a scope at some signals of the CYPD5225 i have seen that the CYPD5225 activates (low level on the signal) the interrupt line I2C_INT_EC.
What does it means ?
Why the power delivery CYPD5225 activates this I2C_INT_EC ?
The activation of the signal is done immediately after the board is powered on, and this signal stay at a zero level all the time. See file scope_6.jpg enclosed (channel 1 (yellow) signal I2C_SCL_SCB1_EC; channel 2 (green) signal I2C_SDA_SCB1_EC; channel 4 (red) signal I2C_INT_EC).
Our design is "EC LESS" how can i specified it in the configuration on the power delivery.
Thank you for help,
TD83
USB EZ-PD Type-C
The I2C_INT_EC is an output pin used to interrupt the Embedded Controller when there is a state change.
This block is also used by the bootloader. Please refer the EZ-PD Host SDK for more details.
Abhilash P
Abhilash P
