USB EZ-PD™ Type-C Forum Discussions
MaLi_3529141
25 replies posted 25 sign-ins 10 replies posted
Dear,
Does CYPD4236 Example have I2C_Write() but no I2C Read.
If I also need to use I2C Read, is there a reference example that I can use?
Manu
ShifangZ_26
10 likes given 250 sign-ins 1000 replies posted
Hi Manu,
CYPD4236 example code do not write additional I2C read for referring to. But you can get the API of I2C Read from I2C master component datasheet.
You can use it  as per your requirements.
Lisa
ShifangZ_26
Hi Manu,
Lisa
MaLi_3529141
Dear Lisa,
1. Do I need to call the function first to enable SCB_I2CMasterReadBuf()?
2. Can MUX_CTRL_I2CMasterReadBuf() in the example code be used?
Manu
ShifangZ_26
Hello Manu,
You can use it directly without additional initialization.
Lisa
