USB EZ-PD™ Type-C Forum Discussions
Danio_A
5 replies posted 10 sign-ins 5 likes given
Hello ,
I need to configure it as RX for portrait transfer。
What should I pay attention to in the configuration of CYPD4226 Sink? I only found the reference routine of Notebook in PSCO Create.
Where can I find the configuration routines for Sink?
Thanks ^,^
Wang_Fred
100 replies posted 10 likes received 25 solutions authored
Can you clarify more about your requirements of portrait transfer? it's a kind of monitor?
Besides, please confirm -
1. which code you are using on your design? is the CYPD4226 notebook design available from PSoC Creator?
2. is the hardware your own customized board? possible to upload the schematic?
It looks from the cc log, CYPD4226(UFP device) has NACK response to ENTER MODE command from DFP device.  Is this behavior 100% reproduced?  Have you ever tried the config for monitor?
 Thanks, Fred
Wang_Fred
 Thanks, Fred
Danio_A
Hi,Fred
Thank you for your reply, Fred. As you said, I am using the notebook project, and I will try to use the monitor configuration to try.
Thanks again
Thanks, Danio
