Ivan_Lee
5 likes given 100 sign-ins First like received
Not all of CYPD4126 pin can be a ADC input, correct?
which pin can be ADC input, can you list it ?
Sananya_14
The default firmware in the host SDK does not support ADC measuring GPIOs after P2.3. Hence you are able to sample P1.5 but not P2.7.
Sananya
Ivan_Lee
I use the same code to test two pins - P1.5 and P2.7
if adc input is P1.5, the CCG4 can get the ADC sampling value .
if adc input is P2.7, the CCG4 can't get the ADC sampling value
Sananya_14
All pins which are designated as a GPIO in the datasheet can be used as an ADC input.
-Please let us know which project and SDK version you are using?
-Please also let us know your hardware setup? (DVK/custom board)
Sananya
1. custom board
2. Host SDK.Version 3.3.1
Sananya_14
Sananya
