Mar 08, 2021
11:33 PM
Mar 08, 2021
11:33 PM
12:20 AM
Mar 10, 2021
12:20 AM
1. 11098024基于CYPD4225。如果您使用的是CYPD4125,那么可以将其用作参考,因为它们都是PD2.0设备。
[1098024 is based on CYPD4225. If you are using CYPD4125, you can use this as reference, since both of them is PD2.0 device.]
TID
1098024
MODEL/PART NUMBER
CYPD4225-40LQXIT
PRODUCT REVISION
2. 建议您使用CYPD4126进行进一步的新设计,TID信息如下:
[Recommend you use CYPD4126 for further new design, the TID information is below:]
TID
1090040
MODEL/PART NUMBER
CYPD4126
Lisa
