- Email to a Friend
I'm facing a problem while developing the firmware for a 100W power adapter.
I programmed the CYPD3196 via SWD and J-Link. Afterwards I could not program it a second time. In openocd I get the error "DP: cannot read IDR".
I suppose I have chosen the wrong bootloader. Because I was not able to find the bootloader for the CYPD3196, I utilzed the one for CYPD3175. Is it possible that this is interrelated?
Where can I find the correct bootloader files for the CYPD3196?
Is it possible to reprogram the chip?
USB EZ-PD Type-C
- Email to a Friend
CYPD3196 can be reprogrammed multiple times and SWD doesn't require or depend on any bootloader.
I think you are not able to reprogram because you have programmed the IC with the wrong part firmware. Can you please try to erase the flash first using J-Link and try reprogramming it again.
For firmware and bootloaders of CYPD3196, you will have to contact local sales/FAE and get it as its confidential.
Pranava
- Email to a Friend
Thanks for the response.
Unfortunately I can't erase the flash because it is not even possible to connect to the chip. Is there anything else I can do to erase the flash and start from scratch?
Do you have any contact information for local sales/FAE?
- Email to a Friend
There is no other way other than erasing the flash and reprogramming.
Regarding the local sales office, please locate the nearest office and contact them - https://www.infineon.com/cms/en/about-infineon/company/find-a-location/
Pranava
