CYPD3177 pin definition clarification
Live Webinar: USB-C adoption. Simple & Cost-efficient solutions | April 18th @9am or 5pm CEST. Register now !
NiPr_4097786
First like received
Hi, I would like clarification on the use of the VDC_OUT pin on CYPD3177. I will be using this in a system where the main VBUS gate is not controlled by CYPD3177. So, VBUS_FET_EN and SAFE_POWER_EN will remain disconnected.
I would like to know the expected operation of CYPD3177 if VDC_OUT is left floating, grounded, tied to VBUS_IN, etc.
I would also like assurance that the D+/D- pins can be placed in parallel with a typical USB2 HS device, as this is not specified in the datasheet and the development board does not break out these pins.
Thank you
