Webinar: USB-C adoption. Simple & Cost-efficient solutions | available on-demand. Watch now !
huab_867446
Dear,
I am not sure if I understand the usage of D+/D- well. In datasheet of the part number CYPD3177-24LQXQ., the D+/D- should be keep open of no connect, while in its EVK the D*/D- are connected to the USB connector.
Would you please help me and let me know which option is correct?
Abhilash_P
50 likes received 500 replies posted 250 solutions authored
   The D+ and D- pins on the EVK is connected to support additional protocols for future purposes.
Please refer to the section 2.3 in the CY4533_EZ-PD Barrel Connector Replacement guide.
The shot from the section is attached below,
Please let us know if you need any further understanding.
Abhilash P
Abhilash_P
Abhilash P
Thanks Abhilash for you reply.
So, do you recommend to connect them if I design a new board or not? Moreover,  are these pins able to damage the chip or not?
Abhilash_P
  It is usually not recommended if there are no future plans for supporting additional protocols.
No, it doesnt damage the chip. They are ESD protected.
Abhilash P
We are planning to connect the D+/D- pins to a USB to UART chip (CP2102). Do you recommend to connect these pins through CYPD or neglect this connection? I mean make a direct connection from USB-C connector to the translator chip without make any connection to the CYPD chip.
Abhilash_P
  Both the options are recommended.
Abhilash P
