I'm using CYPD3175 with MAX25430 in my design.
does any one used this combination before?
now i dont have any clue how to use CYPD3175 to communicate with MAX25430.
is there any example i can find? Thanks!
- cypd3175
Hi @MajorZhu ,
Since Automotive SDK Installer will be released at FY23 Q1, I'm not sure if it is available for the customers now.
EZ-PD™ CCGx Power SDK may be more suitable for you, I think you can use the CLA project as your I2C communication reference, the corresponding evaluation board is CY4532.
Neo
Hi @MajorZhu ,
I think you are using the ADI MAX25430A Evaluation Kit, Infineon provides the Automotive SDK Installer for your reference.
Automotive SDK includes a USB Type-C/PD™ specification compliant protocol stack, middleware libraries, reference applications and documentation. The reference firmware is provided in form of workspaces that can be imported in Modus Toolbox.
Neo
Hi Neo,
Thanks for your help.
yes, according to the MAX25430A EVB, i designed my own board.
i will study the SDK documents. thanks again!
Hi @MajorZhu ,
Neo
