I'm using the SDK CYPD3171-24LQXQ_pb, and when Power Bank work under sink mode, does it support PD3.0 or not?
Why in EZ-PD Configuration Utility Sink Settings only BC1.2 and Apple charger are supported?How could I add other protocols like PD or QC?
And I used my board with the SDK CYPD3171-24LQXQ_pb, it works in sink mode, and the side of power source supports PD3.0 and QC3.0, why my board only get 9V VBUS from the power source and I changed the Sink PDO as 12V but will not get 12V, how can I get the 12V from the power source?
>>The CYPD3171-24LQXQ_pb supports PD 3.0 specification.
>> CCG3PA in sink charging mode (Power Bank solution) supports BC 1.2 and Apple charging only, it does not support QC or AFC.
>> Ensure that the source supports 12 V to power the sink.
Can you share the source PDOs or the cc logs showing source_caps.
Mallika
Mallika
Hello Mallika,
Thanks a lot, I only want to use the sink mode, so I replaced CYPD3171, and I changed to BCR(CYPD3177).
Manon
