I generated a CYPD3125-40LQXIT.hex file from PSoC creator. Open the hex file in PSoC programmer, whose 5 pin connector are connected at follows,
VTARG to 3V3
GND to GND
XRES to CY_XRES
SCLK to CY_SWD0_CLK
SDAT to CY_SWD0_DAT
Selected programmer mode "Reset". Programming device failed. Notice the "Program finished at 1..."
I disconnected the XRES(reset) line and set programmer mode to "Power Cycle", still failed. Notice the "Program finished at 9..."
Can anyone help?
Hello, gkopins,
Thank you for posting on Infineon Community.
I understand that you are not able to update the firmware via SWD.
There does not seem to be an issue with your PSoC Programmer configuration.
If the CCG3 device is powered using an onboard power supply, it can be programmed using the reset programming.
If you are connecting VDD, you can use both reset or power cycling.
Please make sure that the pins are physically connected using a tester.
When using Power Cycle mode, please turn off any onboard power supply.
If you are using the CY4531 evaluation kit, set jumper J3 to 2-3 position.
Pablo
Hello, gkopins,
Pablo
