I have tried to update the firmware of the CYPD3123 device using the EZ-PD Configuration Utility software tool. If i used the boot-loader mode means the firmware update process is success, but if i used normal mode means the firmware update process is failed. Can any one tell me the reason for this issue?
Hari kumar
Hi Hari,
Is there any possible to let us know what's the firmware update process is failed? Is there any screen copy about this?
You may need difference between Using Firmware to Flash and Using Bootloader to Flash, you could find it on section 4.6.1.2 Dual Firmware Mode in EZ-PD™ Configuration Utility User Manual.
Lisa
Hi Hari,
As per your message log, there are no fail message. I pasted as below:
Starting Device Discovery.
Entered flashing mode successfully.
1 HID devices found.
0 USB-Serial Bridge devices found.
Device Discovery completed.
FW Image 1 is valid.
Starting CCG firmware update over I2C interface.
Jump to Boot command successful.
All flash rows updated. Validating downloaded firmware checksum
CCGX is trying to flash second firmware or config binary
FW Image 2 is valid.
Reset command successful.
Firmware update completed successfully
Flash update procedure succeeded.
Lisa
