Hi All
CYPD3120-40LQXI change to DRP , How to modify FW ?
Attach HEX file : CYPD3120-40LQXI_dp_dongle.hex
You'll need to manually override the config table in the firmware.
Please check the following example code to change its power role to DRP and add source PDO:
dpm_update_port_config(0, 2, 0, 1, 2);
pd_do_t SRC_PDO[1];
SRC_PDO[0].val = 0x0001912C; //5V 3A (This value can check on xml file created by EZ-PD Configuration Utility)
dpm_update_src_cap(0, 1, SRC_PDO);
dpm_update_src_cap_mask (0, 0x01);
And you need to provide the corresponding power to the VBUS since it is a power source. External code is needed to control the power device like buck boost.
Eddie
pd_do_t SRC_PDO[1];
Eddie
Hi Eddie
Thanks for your response.
pd_do_t SRC_PDO[1];
Please tell me which .C file to new add .
is completed;you can check "CYPD3120-40LQXI_dp_dongle.hex.zip"
You could add them to main function.
