Hi all,
Browsing all your files on this site i only encoutred CYPD3125 files.
Would really appericiate if you can provide me with the CYPD3120 Code i can Build using PSoc creator and load using USB interface using EZ-PD.
Also, any other SW tips will be helpful.
Ido
Hi Ido,
Can you try building the same project with PSoC Creator 3.3 This will avoid compiler errors.
Pranava
Hi Ido,
During our Website migration, we have somehow missed sharing CCGx SDK that contains source code for CYPD3120 DP Dongle project. I am attaching the setup file here, please use this until we rectify the issue.
You can use Configuration Utility to configure the device - https://www.infineon.com/cms/en/design-support/tools/configuration/usb-ez-pd-configuration-utility/
PSoC Creator is necessary to use the SDK - https://www.infineon.com/cms/en/design-support/tools/sdk/psoc-software/psoc-creator/?utm_source=cypr...
Please let me know if you face any issues while using the SDK.
Pranava
Thanks for the information!
The software askes for Cypress Document Manager 1.0.0.769 and i cant seem to find it.
any help?
ido
Please install PSoC Creator 3.3 version to get the Cypress Document Manager - https://www.infineon.com/cms/en/design-support/tools/tools-archive/psoc-creator-archive/#!?fileId=8a...
Apologies for this inconvenience 🙂
Pranava
Hi
So i downloaded PSOC3.3 and installed the SDK...
After updating my components on PSOC4.4 (cause 3.3 isn't supported anymore) i cant build the project - i would like to reach a point where i build the project and flash the ccg3 cypd3120 i have with its default code succesfully.
any help?
What exactly is the error you are facing while building the project?
Did you create the project using above option? If so, please give me the build error log
Pranava
So the process i did is as follows -
1) opened PSoc 4.4
2) open cypd3120 dp dongle .cywrk (the one in your photo)
3) run update device (the program requires it)
3) run Build or Clean and Build
4) get an error -
Tried it on 2 different computers and got the same outcome.
ido
Hi Ido,
Pranava
Hi!
I already tried it before ou replyed...
For some reason the SDK's are not compatible with PSOC3.3...
Can you try to do the process i described eralier and tell me how to overcome the compiler errors?
Ido
Update - i installed a different PSOC3.3 version (the dp update) and now the SDK is recognized - ill keep you updated.
Hi -
update - it worked!
Thanks!
