Our design scheme is: through CYPD4226 chip to control tusb1064 to complete the transmission of video signals from PC to FPGA. Shall we switch the working mode of CYPD4226 to UFP? We imported the CYPD4226 notebook reference project, but it doesn't seem to get the correct CC log. Does the reference project support our design? If not, what should we change?
thanks, Danio
Hi Danio,
1. The last ACK of 9A is the response that will only appear after my monitor is started.
Ans : yes, that 9A is for final attention message after the Dp configured Ack. it is the expected message as per DP spec.
2. When I turn off the monitor or disconnect the monitor, a LOG message like "HARD RESET" will appear, but the handshake will continue when I connect again.
Ans : while disconnecting you have to get the HPD_IRQ signal for disable or EXIT mode VDM, not the HARD RESET.
but in your attached log I could not be able to find any hard reset.
please share the Hard reset log to analyze little more.
Thanks & Regards
Mohamed Rahmathulla
Hi Danio,
Thank you for posting in infineon community.
i understand from the PD log that your are connecting your display in this port. you can use monitor reference project for this application with proper pin assignment.
also i couldn't able to open .cyacd file, please share the proper file to analyze.
Thanks & Regards
Mohamed Rahmathulla
Thank you for your answer. I have questions here:
1. What is the monitor reference project?
I only found the reference project for the notebook in CYPD4226. There is no reference project for monitor, can you provide it if you have one?
2.cyacd file or xml file should be opened through EZ_PD configuration untility software. I hope you can help us check the configuration.
3. With respect to PD log, is it certain that the handshake process has been successful?
Thanks & Regards
Danio_A
Hi Danio,
You can create monitor application from EZ_PD configuration utility software.
File-> New, select CC4-> monitor (select the respective IC from "Device parameter" tab.
and current notebook firmware is configuring as a DP alt mode but after successful configuration, PD log shows the hard reset, it is not the expected behavior. please check hardware whether any disconnection or actual hardware reset.
Thanks & Regards
Mohamed Rahmathulla
Thanks & Regards
Mohamed Rahmathulla
Hi Danio,
Yes, Handshake looks fine, Log shows that the notebook firmware successfully configured and entered into DP (Alt mode) state machine.
Thanks & Regards
Mohamed Rahmathulla
Hi Mohamed Rahmathulla,
I think the PDlog I got now (see the attachment) is complete. However, some phenomena can be described:
Could you help me check whether PDLOG is complete or correct, and whether there is any abnormality in the current phenomenon?
Hi Danio,
Thanks & Regards
Mohamed Rahmathulla
