Webinar: USB-C adoption. Simple & Cost-efficient solutions | available on-demand. Watch now !
diricse
5 replies posted 5 sign-ins First solution authored
why  DS1 port Only 1A 5v power?  is If set it 2.3A at 20v?
MallikaK_22
50 likes received 750 replies posted 250 solutions authored
Please don't open the EZ PD Configuration Utility. You have to use the HX3PD Configuration Utility for updating and configuring the HX3PD firmware. EZ-PD Configuration Utility in turn is launched by HX3PD Configuration Utility to configure DMC and PD Controller firmware. You don't need to launch EZ PD Configuration Utility individually.
Please follow the steps as mentioned in the HX3PD Configuration Utility user guide.
Mallika
MallikaK_22
DS1 port supports PD3.0. Thus the maximum charging current it supports is 5A at 20V.
Mallika
diricse
but my buy bill is  1A at 5v,power is 5w,why?us port is 2.3A at
 20v
MallikaK_22
5V,1 A is the default configuration on DS1. The CY6611 firmware can be configured to support charging at higher
voltage levels. Kindly refer to Programming the HX3PD Controller chapter in the CY6611HX3PD Kit Guide to configure the HX3PD firmware.
https://www.cypress.com/file/511276/download
Mallika
diricse
I  Install  configuration tool, but  find dev  fail,why?
MallikaK_22
Mallika
