hlwn
First reply posted First question asked First like given
Hi Everyone,
I would like to ask , is source code of CY6611 EZ-USB HX3PD EVK available?
Is it possible to program CY6611 EZ-USB HX3PD EVK through source code?
Liwan
Sananya_14
Hi Liwan,
Yes, the source code is available for HX3PD based on the CY6611 EVK. Please find the complete source code with the Dock SDK and the binaries only with HX3PD firmware.
The programming is possible using SWD programming (using MiniProg4) or USB programming using the HX3PD Configuration utility.
Sananya
Sananya_14
Hi Liwan,
Sananya
Hi Sananya,
After following the link above, Dock SDK, and install EZ-PD CCGx Dock SDK v3.3 Single Package, may I ask how to find the source code? It seems after the installation, EZ-PD Configuration Utility is launched. And I am bit unsure how to get into the source code.
Liwan
Sananya_14
Hi Liwan,
Please refer to the HX3PD source code at- <install directory>\Cypress\EZ-PD CCGx Dock SDK\Firmware\projects\HX3PD_HUB
You should find the HX3PD PD controller and DMC projects in that path, both can be opened using PSoC Creator.
Sananya
