crne_4736256
CY4533 BRC Evaluation kit
Doc #: 630-60538-01
Sheet: 5
Section: B4
Pins: MH1, MH2, MH3, MH4
are these pins actually the case pins?
Want to verify before I continue.
MallikaK_22
250 solutions authored 500 replies posted 250 replies posted
These are unused pins on the Type C connector.
The receptacle datasheet also indicates the same https://datasheet.octopart.com/CU1816SAH1MD2R0-LF-HC-CviLux-datasheet-103289541.pdf
The pins basically denote the connection of the receptacle through the mounting hole.
Mallika
MallikaK_22
Mallika
