Hi All,
To Send Run time request after PD contract I am using "pd_prot_send_data_msg()" CCG3PA API,
I am able to populate request structure, send using the above mentioned api.
Accept message also received from the DFP/Source, but after sending GoodCRC from CCG3PA within ~650uSec (from the EOP of GoodCRC) SoftReset is initiated.
Please find the attached CC-line sniffer captures. Let me know what is the additional configuration missing for getting the expected result in this case.
Thanks & Regards
Prasanna
ispn:39570:1:0
l1:314:1:0
Hi Prasanna,
Let's tracking this question in the threads CY4532 EVK, Initiating PD Data message from CCG3PA
Lisa
Hi Prasanna,
Lisa
Hi Lisa,
Thank you, Do you have any solution for the issue that I am facing. If you have can provide your inputs in the thread that you mentioned.
Best Regards
Prasanna
