And I have purchased CY4500, and installed the latest software (name: ezpdprotocolanalyzer_3.1.0_Windows_x86-x64.exe) on Win7 and Win10. After installing the driver, there is a tip for these two computers which tells me that 'Unable to scan for USB devices: javax.usb.UsbPlatformException: USB error 99: Unable to get USB device list:'. I also see Cypress ED-PD Analyzer is in the libusb-win32 devices from the device manager. That means I had sucessfully installed usb driver. I also reboot these two computers, but problems still occurred.
ispn:39566:1:0
l1:314:1:0
USBEZ-PDType-C
I think the hardware is not bound to proper driver. That is the reason why it cant update firmware.
Please install the following software which also installs the correct driver necessary. - https://www.infineon.com/cms/en/design-support/tools/configuration/usb-ez-pd-configuration-utility/
Also in Device Configurator make sure you have right driver bound to the CY4500 hardware.
Please refer to similar issue in following link - https://community.infineon.com/t5/USB-EZ-PD-Type-C/CY4500-Device-detected-in-EZ-PD-but-can-t-update-...
Knowledge base article on EZ-PD Protocol Analyzer Utility - https://community.infineon.com/t5/Knowledge-Base-Articles/Using-the-EZ-PD-Protocol-Analyzer-Utility-...
Pranava
Can you please specify the version of Java that is installed in the PCs?
Pranava
java verion "1.8.0_311" in Win 7
java verion "1.8.0_281" in Win 10
This error seems to be specific to Java. Can you please try reinstalling the same and check if it works?
Pranava
Yes, I uninstalled all the JAVA and reinstalled again. The new java version is java verion "1.8.0_311" in Win 7. But the same error still happens.
Pranava
