Please refer the following similar customer query,
Let me know if you were able to solve the issue. If no, I can assist you with further debugging.
Abhilash P
Hi, Thank you for the quick answer.
I follower your link, but I don't have a folder Cypress in my C:\Program Files (x86).
Default installation folder is C:\Users\"username"\Cypress\EZ-PD Protocol Analyzer Utility and there is no folder "drivers".
Can you please try reinstalling the utility software.
The drivers folder has to be there in the below mentioned path,
C:\Program Files (x86)\Cypress\EZ-PD Analyzer Utility\drivers
Attached the files under drivers folder,
Abhilash P
Hello, I reinstalled several times on different PCs, but every time the result is the same.
Can you send this folder on my email?
alexandr.kobzev@antilatency.com
Sure.
Abhilash P
Hi Abhilash,
Can you send me the driver of CY4500, too?
I also cannot found the driver folder after installed the EZ-PD Protocol analyzer version 3.1.0.
I am using Windows 10 64-bit OS.
Delo
