Please install both version 1.0.0 and 3.x.x of the EZ-PD Protocol Analyzer Utility software - https://softwaretools.infineon.com/tools/com.ifx.tb.tool.ezpdprotocolanalyzer?_ga=2.267295822.159461...
The older installer will have the driver required during CY4500 firmware update, upon updating the firmware you can use 3.x.x to use the analyzer.
Pranava
Please refer the following similar customer query,
Let me know if you were able to solve the issue. If no, I can assist you with further debugging.
Abhilash P
Hi, Thank you for the quick answer.
I follower your link, but I don't have a folder Cypress in my C:\Program Files (x86).
Default installation folder is C:\Users\"username"\Cypress\EZ-PD Protocol Analyzer Utility and there is no folder "drivers".
Can you please try reinstalling the utility software.
The drivers folder has to be there in the below mentioned path,
C:\Program Files (x86)\Cypress\EZ-PD Analyzer Utility\drivers
Attached the files under drivers folder,
Abhilash P
Hello, I reinstalled several times on different PCs, but every time the result is the same.
Can you send this folder on my email?
alexandr.kobzev@antilatency.com
Sure.
Abhilash P
Hi Abhilash,
Can you send me the driver of CY4500, too?
I also cannot found the driver folder after installed the EZ-PD Protocol analyzer version 3.1.0.
I am using Windows 10 64-bit OS.
Delo
Pranava
