Dear all,
Can you send me the driver of CY4500, to
Liam.liu@corp.ovt.com
I also cannot found the driver folder after installed the EZ-PD Protocol analyzer version 3.1.0.
I am using Windows 10 64-bit OS.
Thank you.
ispn:39566:1:0
l1:314:1:0
USBEZ-PDType-C
it doesnt support USB-C PD3.0, for that you have to upgrade to new version.
kindly update to newer version once you installed your driver manually.
Thanks & Regards
Mohamed Rahmathulla
Thank you for posting in infineon community.
The driver for this Analyzer will get installed automatically.
update the firmware using EZ-PD Protocol analyzer which mentioned in the above image incase the driver is not installed automatically.
Thanks & Regards
Mohamed Rahmathulla
Thank you,
The CY4500 driver was not automatically installed.
And the firmware cannot be updated because the driver is not installed.
Log-in to below link with your infineon credential and download the version 1.0.0 and get it installed.
https://softwaretools.infineon.com/tools/com.ifx.tb.tool.ezpdprotocolanalyzer
you will get the driver file in the installed location. kindly use that location the install the driver and update protocol analyser to latest version.
Thanks & Regards
Mohamed Rahmathulla
Does the version 1.0.0 support USB-C PD3.0 decoding?
Thanks & Regards
Mohamed Rahmathulla
