USB EZ-PD™ Type-C
evst_4367356
New Contributor
I have just purchased Cypress CY4500 (Rev 09) from digikey. I have installed EZ-PD software and it detects the device but i can't update the firmware. Please see the attached image.cy4500.png
PranavaYN
https://www.cypress.com/documentation/development-kitsboards/cy4500-ez-pd-protocol-analyzer
Please install "Download CY4500 EZ-PD Protocol Analyzer EXE" from the above mentioned link. Installing this will automatically install the drivers necessary. If you still face issue you can manually reinstall it from the path i mentioned before.
Pranava
Pranava
PranavaYN
This occurs if a proper driver is not installed. Can you please try installing drivers from
C:\Program Files (x86)\Cypress\CY4500 EZ-PD Protocol Analyzer\1.0\EZ-PD Analyzer Utility
Also make sure proper driver is bound to the hardware in Device Manager
Pranava
Pranava
evst_4367356
New Contributor
There is no driver in the latest software. Can you provide a link?driver.png
PranavaYN
Pranava
Pranava
evst_4367356
New Contributor
Ok thanks it's working now. I assumed "CY4500 EZ-PD Protocol Analyzer EXE"" was an old version since it hasn't been updated since 2016.
What's the difference between this and the "Utility"?
PranavaYN
Hi
CY4500 EZ-PD Protocol Analyzer EXE installs drivers related to CY4500 kit. It also includes earlier version of EZ-PD Analyzer Utility( This utility can only decode PD2.0 packets).
Pranava
Pranava
evst_4367356
New Contributor
Thanks for the quick response and support.
