Linux analyzer utility shows empty data(screenshot attached), while the Windows version works fine on same analyzer HW.
Linux version:
Linux XXXX #60~20.04.1-Ubuntu SMP Thu May 6 09:52:46 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
java version "1.8.0_291"
Java(TM) SE Runtime Environment (build 1.8.0_291-b10)
Java HotSpot(TM) 64-Bit Server VM (build 25.291-b10, mixed mode)
EZ version:Cypress Semiconductor Corporation
CY4500 EZ-PD™ Protocol Analyzer Utility
Version : 3.1.0
Build : 31
Copyright © Cypress Semiconductor 2020
Thank you very much.
USB EZ-PD Type-C
Please let me know if you have followed the below mentioned steps,
Installing the Java 8:
- Download JRE binaries in *.tar.gz for Linux from https://www.java.com/en/download/manual.jsp
- Create a directory to install JRE with the command:
sudo mkdir/usr/local/java - Move the JRE binaries into the directory:
sudo mv jre-8u281-linux-x64.tar.gz /usr/local/java - Go to the install directory:
cd /usr/local/java - Unpack the tarball:
sudo tar zxvf jre-8u281-linux-x64.tar.gz - To save space, delete the tarball by running:
sudo rm jre-8u281-linux-x64.tar.gz - Let the system know where JRE is installed:
sudo update-alternatives --install "/usr/bin/java" "java" "/usr/local/java/jre1.8.0_281/bin/java" 1.
Installing the analyzer utility,
- Download the latest version of the EZ-PD Protocol Analyzer Utility. Extract the zip package and open a terminal inside the extracted
directory. - Execute the following one-time commands:
export SWT_GTK3=0
chmod a+x CY4500_EZ_PD_Protocol_Analyzer_Utility - The EZ-PD Protocol Analyzer Utility 3.1.0 should be invoked in superuser mode. Command: sudo ./CY4500_EZ_PD_Protocol_Analyzer_Utility
Abhilash P
export SWT_GTK3=0
Abhilash P
I think the last step is the key:
Problem is solved. Thanks for the quick reply.
