USB EZ-PD™ Type-C Forum Discussions
MedinaNeil
First like given First question asked Welcome!
Is it possible to run this device off a (nominal ) 5V DC supply and turn off the Type-PD functionality of this device leaving only the Type-C functionality (at 3A) and the legacy functionality (e.g. USB BC 1.2 etc).
Or possibly restricting the PD advertising to 15W  (5V 3A) whilst providing the Type-C and Legacy charging capability as stated above?
Many Thanks
Neil
Wang_Fred
100 replies posted 10 likes received 25 solutions authored
Hello Neil,
supplement to last reply -
> yes, it could be simply achieved with configuring the source PDOs to only 5V/3A. The configuration tool is https://www.infineon.com/cms/en/design-support/tools/configuration/usb-ez-pd-configuration-utility/#... The PD capability is still reserved.
> This also could be achieved to disable PD and reserve type-c capability only. Take either power bank or power adapter example project inside CCGx Power SDK(ez-pd-ccgx-power-software-development-kit/) as example, you need to call API - dpm_pe_stop() before while loop inside main function.
Thanks, Fred
Neo_Qin
100 sign-ins 10 likes received 50 replies posted
Hi Neil,
I think it's doable, the CCG3PA has the ability to support PD3.1 PPS and 2*legacy/proprietary charging blocks (Supports QC 4.0, Apple charging 2.4A, AFC, BC 1.2), integrates all required terminations on DP/DM lines, supports one USB Type-C port and one Type-A port.
For your application, you need a dedicated firmware support.
I'm not sure whether you can achieve your goal by configuring the existing firmware, I will confirm it.
By the way, could you kindly provide us which CCG3PA IC you selected?
Neo
Wang_Fred
Hello Neil,
Thanks, Fred
