SPEC:
The CCG5 has power supply inputs at V5V_P1 and V5V_P2 pins for providing power to EMCA cables through
integrated VCONN FETs. There are two VCONN FETs in CCG5 per Type-C port to power CC1_P1/P2 and
CC2_P1/P2 pins. These FETs can provide a minimum of 1.5 W on the CC1 and CC2 pins for EMCA cable
(1). if V5V_P1 is 5V,
does it mean the Vconn Source is 1.5W / 5V = 0.3A ?
and configuaration - Vconn OCP setting is threshold = 30% , Debouce period = 1ms
does it mean Vconn OCP trigger point is 0.3A x 1.3 = 0.39A and debouce = 1ms
(1). if V5V_P1 is 3.3V ,
does it mean the Vconn Source is 1.5W / 3.3V = 0.4545A ?
does it mean Vconn OCP trigger point is 0.4545A x 1.3 = 0.59A and debouce = 1ms
but SEPC :
In a notebook design, VCONN supplies power to the electronically marked cable attached to it. VCONN FETs on
CC lines can handle a current up to 0.5 A
it mean max vocnn ocp trigger point is 0.5A ??
USB EZ-PD Type-C
Hi ,
Thank you for creating a post in infineon developer community.
As per the Data sheet, V5V_P1 & V5V_P2 could not able to support 3.3v
it is correct for 5v and threshold of 30% is = 0.39Amp of OCP and Debouce period is 1ms as per the configuration
please refer below table for min and max of OCP
Thanks and Regards,
Mohamed Rahmathulla
An Infineon Technologies Company
Hi ,
Thanks and Regards,
Mohamed Rahmathulla
