CCG5 Host SDK - UVP / SCP
Live Webinar: USB-C adoption. Simple & Cost-efficient solutions | April 18th @9am or 5pm CEST. Register now !
Ivan_Lee
Distributor - Zenitron(GC)
100 replies posted 5 likes given 100 sign-ins
The Cypress EZ PD™ CCG x Host SDK User Guide  :
  • The key features of CCG x notebook port controller solution s are:
    ▪ Compliant to USB PD specification Revision 3.0 Version 1. 1
    ▪ Compliant to USB T ype C Specification Revision 1.2
    ▪ Support Type C VBUS OVP and OCP.
The SDK document doesn't mention about UVP / SCP supported , Why does SDK can't support UVP / SCP ,
and how to eanble UVP and SCP ?
Sananya_14
Hi Ivan,
Please follow the steps below to enable UVP in the latest Host SDK project-
  1. Add VBUS_UVP_ENABLE and set it to 1 in config.h
  2. Set VBUS_UVP_MODE to VBUS_UVP_MODE_INT_COMP_AUTOCTRL in config.h
  3. Enable the UVP related parameters in the EZ-PD Configuration utility by creating a new configuration of "Generic" type as shown below. The debounce should ideally be about 10us and threshold should be set to 20 (%) or higher.
Please test it and let us know if there are any issues.
Sananya
Sananya_14
UVP feature is usually supported in source-only applications and as mentioned in the User Guide, the UV comparator is unused in the default CCG5 firmware and can be enabled if required. The SCP feature is not supported by the CCG5 hardware and hence cant be enabled in the firmware.
Sananya
Ivan_Lee
Hi, Sananya ,
How to enable UVP feature? i didn't see any related definition about UVP in config.h
BR
Ivan
Sananya_14
Hi Ivan,
Sananya
