USB EZ-PD™ Type-C Forum Discussions
Ivan_Lee
100 sign-ins First like received 50 replies posted
Hi, Sir,
Does CCG4 have unique ID inside chip?
if have, how to get the unique number ?
BR
Ivan
PranavaYN
Moderator 50 likes received First comment on KBA First question asked
CCG4 doesn't have any Unique ID which is unique to each chip as it's nowhere defined in the spec. However you can use User Parameters section of Configuration table to implement this unique ID yourselves.
https://www.infineon.com/cms/en/design-support/tools/configuration/usb-ez-pd-configuration-utility/
Pranava
ShifangZ_26
Moderator 1000 replies posted 750 replies posted 500 solutions authored
Hi Ivan,
Could you please kindly clarify the define of unique ID you have been mentioned?
Lisa
Ivan_Lee
Each chip has its own serial number and different with others.
PranavaYN
Pranava
