USB EZ-PD™ Type-C Forum Discussions
DaEr_349131
50 sign-ins 5 comments on KBA First comment on KBA
Are there any updates to the CCG3PA stack so that the device can be updated via UART or I2C?
it's ok to flash it once via SWD, but on the field we can't rely on SWD nor CC to upgrade the firmware.
PranavaYN
500 replies posted 250 solutions authored 50 likes received
Please find the CCG3PA power adapter and power bank projects in CCGx Power SDK.
Both CC Bootloader source projects are present within the SDK.
cc_src_boot.cydsn project is found in EZ-PD CCGx Power SDK\CCGx\Firmware\projects\CYPD3175-24LQXQ_pa_direct_fb\CYPD3175-24LQXQ_pa_direct_fb.cydsn path and cc_snk_boot.cydsn is found in EZ-PD CCGx Power SDK\CCGx\Firmware\projects\CYPD3171-24LQXQ_pb\CYPD3171-24LQXQ_pb.cydsn
Pranava
PranavaYN
CCG3PA supports CC bootloading as well as SWD programming. We have no plans to implement firmware update over I2C for CCG3PA.
Pranava
what is your proposal to update the ccg3pa firmware on the field?
it's quite uncommon to implement a full swd host  / daplink on the main mcu to enable fw-updates.
curious why you have this limitation when other ccg parts have the standard i2c and uart bootloaders in place?
PranavaYN
Programming over CC interface is convenient method to update firmware in CCG3PA. You can use CY4532(https://www.cypress.com/documentation/development-kitsboards/cy4532-ez-pd-ccg3pa-evaluation-kit) Power Board as a programmer and EZ-PD Configuration Utility tool to program.
Since CCG3PA part is used in Power adapter and Power Bank applications, the only interface that is accessible in the end product would be Type-C port. Therefore, CCG3PA implements CC bootloader and not I2C as in case of other controllers.
Pranava
DaEr_349131
sure, but we need in-system-programming here, we can not require the user to do it via CC nor SWD...
how do we best get the i2c bootloader implemented? can you provide the source-code for the CCG3PA so that we can do this ourselves.
PranavaYN
Pranava
DaEr_349131
right! so theoretically we could take an i2c compatible bootloader from psoc 4 or another ccg (which one?) and migrate it ourselves, correct?
HI,
Yes, you will have to implement it yourself. CCG3 has an I2C bootloader that you can refer to.
Pranava
