USB EZ-PD™ Type-C Forum Discussions
GrWa_2302706
Level 4
50 questions asked 25 replies posted 10 replies posted
Level 4
Hi
1. May I know the ADC sampling rate of CCG3PA ?
2. For the current which is over OCP threshold for 1us time, could that be captured by LSCSA of CCG3PA?
BR
Grace
ShifangZ_26
Moderator 1000 replies posted 750 replies posted 500 solutions authored
Hi Grace,
1. CCG3PA internal ADC main frequency is 1MHz (Max value), the CCG3PA firmware use divider value with 8 for ADC sample. It is about 125KHz.
2. There is OCP denounce time setting in configuration table, 10ms by default. If you could like to capture it, you could set it as 0 to try. Please kindly notice that the OCP event is compactor interrupt triggered.
Lisa
ShifangZ_26
Hi Grace,
Lisa
