I am working on the CCG2 to determine if we can use
this part going forward or if we need to step up to the CCG3PA. Is there anyway to advertise 100W
outputs (20V @ 5A) without the use of an eMarked cable.
We are using a captive cable, and are wondering if there is a way to set up the
program to ignore searching for the eMarked cable to allow the 5A from our
hardwired USB-C cable.
Hi Rob,
Currently, the experience can be shared here is let CCG3PA advertise 20V/5A on CC line, the API you need be called is: dpm_update_def_cable_cap(500).
Lisa
Hi Rob,
Lisa
