Having difficulty setting up the development environment to program CCG2 components.
It appears the EZ-PD Configuration Utility is only capable of changing configuration settings in the CCG parts and not adding logic for additional GPIO.
Documentation points to PSoC Creator for adding logic and pin functionality.
If so, what is the process to enable CCGx support in PSoC Creator?
Attached are screen shots of PSoC Creator with and without CCGx support.
How do I enable CCGx support to the PSoC Creator installation that doesn't currently show that support?
Greg
Hi Greg,
One package to help you add all of CCG2 into PSoC Creator, Download CCGx SDK v3.0.2 Installer (PSoC Creator, EZ-PD Configuration Utility, Firmware stack and ex...
Lisa
Hi Greg,
1. Since you have been attached the screen shots of PSoC Creator with and without CCGx support, I have to request you supply the PSoC Creator revision for reference. Below revision information for your reference.
a. For EZ-PD CCGx SDK, below version is best version for it. Of course, if you installed later version also can use it.
b. For EZ-PD CCGx HOST SDK and EZ-PD CCGx POWER SDK, the best practice version is below:
2. You are correct that the Ez-PD configuration Utility cannot configure a GPIO function. The firmware customer shall be completed by add GPIO operation in PSoC Creator. If you want to know how to add a GPIO into the example project, below link can be reference. This is Application Notes of PSoC4. It is same usage of CCGx devices.
https://china.cypress.com/documentation/application-notes/an86439-psoc-4-using-gpio-pins
Since CCGx is ARM M0+ MCU, so that CCGx is not create duplicate documentation for it.
3. To enable CCGx device, the best way is install concerned SDK. The download link is below:
https://www.cypress.com/documentation/software-and-drivers/ez-pd-software-development-kit
https://www.cypress.com/documentation/software-and-drivers/ez-pd-ccgx-power-software-development-kit
Lisa
Lisa,
Thanks for your quick response.
The rough version of Creator in the pictures attached is noted in the top left corner as 4.2.
The About screens do show the Installed Products.
The installation I have of PSoC Creator 4.2 that has CCG support shows CCG EVK is installed
The installation of PSoC Creator with NO CCG support also shows CCG2 EVK is installed
What needs to be done to allow CCG2 to show up as an option on the Target Device selection screen in PSoC Creator?
We've loaded “Download CCGx SDK v3.0.2 Only (Firmware stack and examples)” from https://www.cypress.com/documentation/software-and-drivers/ez-pd-sdk-v302-ccg2-all-applications-ccg3...
Is there something else needed?
Greg
Hi Greg,
From the screen shot you shared above, the CCG2 is showed up. May I know what's your question? I guess I am confused now.
Lisa
Lisa,
The CCG options don't initially show up when PSoC Creator is installed.
My question is:
- What are the specific steps to add CCG capability to PSoC Creator?
I’m guessing it involves downloading one of the SDKs and some files from one of the CCG kits webpages.
I just kept downloading files and programs until I finally saw the CCG options pop up. I don’t know which files were necessary.
Here’s some of the files and programs I installed after installing PSoC Creator:
- Load the “Download CCGx SDK v3.0.2 Only (Firmware stack and examples)” from https://www.cypress.com/documentation/software-and-drivers/ez-pd-sdk-v302-ccg2-all-applications-ccg3...
- Download and Run “CY4502 EZ PD CCG2 Development Kit Setup Package” from the website CY4502 EZ-PD™ CCG2 Development Kit @ https://www.cypress.com/documentation/development-kitsboards/cy4502-ez-pd-ccg2-development-kit?sourc...
- Download and Run “CY4521 EZ-PD CCG2 Setup” from the website CY4521 EZ-PD™ CCG2 Evaluation Kit @ https://www.cypress.com/documentation/development-kitsboards/cy4521-ez-pd-ccg2-evaluation-kit?source...
I also checked:
If CCG2 projects were loaded to the default location on the computer, they should be @
C:\Program Files (x86)\Cypress\EZ-PD CCGx SDK\CCG2\Firmware\projects\
There should be three example directories:
- Mobile
- Notebook
- Power_Adapter
Verify there’s a “CCGx SDK Files” option in the Windows Start options. If it’s there, does opening that up lead to a CCG2 director that contains both Documentation and Firmware?
If the above instructions are all that's needed, we can mark this as "Correct Answer". If there's additional files or programs required to be able to program CCG2 or any other CCG offerings within PSoC Creator, pleas add that information here.
Thanks for your support.
My question is:
I just kept feeding the customer more files to download and programs to install until he finally saw the CCG options pop up. We don’t know which files were necessary.
Here’s some of the files and programs I instructed him to install:
I also asked him to check:
If CCG2 projects were loaded to the default location on your computer, they should be @
- Mobile
- Notebook
- Power_Adapter
Verify there’s a “CCGx SDK Files” option in the Windows Start options. If it’s there, does opening that up lead to a CCG2 director that contains only Documentation and no Firmware?
Hi Greg,
Lisa
