In PSoC Creator 4.2 i created a new CCG2 Project. I loaded code example CYPD2122-24LQXI_mobile. I updated the components and tried to build the project and got the error message:ERROR: cannot find -lusbpd_gcc.
Any suggestions?
Robert
In the build setting, you should choose ARM MDK Generic for Toolchain.
Eddie
Eddie
Hi Eddie,
I installed mdk528a and set toolchain to ARM MDK Generic, as you adviced. Now i get the following error:
Fatal error: L3900U: Unrecognized option '--vfemode=force'.
The command 'armcc.exe' failed with exit code '1'.
Robert
Hi Robert,
I can successfully compile CYPD2122-24LQXI_mobile after updaing componet with mdk528a. If you still can not successfully compile the project, I suggest you use PSoC Creator 3.3 with ARM MDK Generic. The component will not need updating.
Eddie
Hi, Eddie,
with the PSOC version 3.3 I had already tried it of course, the error is the same.
After I installed PSoC 4.2 and MDK528a on another computer everything works. Why I don't know.
Many thanks for your help
Robert
