USB EZ-PD™ Type-C
dame_4597801
New Contributor II
Is the CCG2 60W Car Charger Reference Design completely standalone, with the provided firmware?
I have no host controller and otherwise need to know if I need to make any firmware changes. The specs of the board are fine as-is for my application.
ShifangZ_26
Yes, you are correct.
The Source capabilities can be configured by Ez-PD configuration Utility.
Lisa
ShifangZ_26
Hello ,
1. Are you using the firmware in the Link?
https://community.cypress.com/t5/Knowledge-Base-Articles/EZ-PD-CCG2-60W-Car-Charger-Reference-Design...
2. If yes, the firmware supporting CC bootloader and SWD programming for firmware upgarde.
Lisa
dame_4597801
New Contributor II
Thanks but that didn't come close to answering my question. Maybe I was not clear. If I use that reference design, exactly as-is, with the supplied firmware, and apply power, will it function properly as a TCPD providing all of the output voltages and currents advertised?
ShifangZ_26
Lisa
