SDK version: ezpdhostsdk_3.4.0_Windows_x86-x64.exe
.\CortexM0\ARM_GCC_541\Debug\hal_ccgx.o .\CortexM0\ARM_GCC_541\Debug\pdss_mx_hal.o .\CortexM0\ARM_GCC_541\Debug\cyfitter_cfg.o .\CortexM0\ARM_GCC_541\Debug\cybootloader.o .\CortexM0\ARM_GCC_541\Debug\cymetadata.o .\CortexM0\ARM_GCC_541\Debug\Cm0Start.o .\CortexM0\ARM_GCC_541\Debug\CYPD5225-96BZXI_notebook.a -mcpu=cortex-m0 -mthumb -l ccgx_hpi_ucsi -l ccgx_pd3 -L Generated_Source\PSoC4 -L .\lib\ccg5_dualport -Wl,-Map,.\CortexM0\ARM_GCC_541\Debug/CYPD5225-96BZXI_notebook.map -T .\cm0gcc.ld -specs=nano.specs -Wl,--gc-sections -flto -Os -g -ffunction-sections -finline-functions -Os -flto -ffat-lto-objects -Wl,--end-group
ERROR: address 0x20240 of G:\temp\CYPD5225-96BZXI_notebook\CYPD5225-96BZXI_notebook.cydsn\CortexM0\ARM_GCC_541\Debug\CYPD5225-96BZXI_notebook.elf section `.text' is not within region `rom'
ERROR: G:\temp\CYPD5225-96BZXI_notebook\CYPD5225-96BZXI_notebook.cydsn\CortexM0\ARM_GCC_541\Debug\CYPD5225-96BZXI_notebook.elf section `.eh_frame' will not fit in region `rom'
ERROR: Firmware binary overlaps with metadata
ERROR: section .cyloadablemeta loaded at [0001fec0,0001feff] overlaps section .text loaded at [0000c400,0002023f]
ERROR: region `rom' overflowed by -256 bytes
collect2.exe: error: ld returned 1 exit status
The command 'arm-none-eabi-gcc.exe' failed with exit code '1'.
Looks like the error is due to PSoC Creator not able to find the cyelftool.exe
Please make sure you are bin directory of PSoC Creator to the Environment variables in your system as shown below.
Also, regarding the latest error, please let me know if linker file or any other files were modified for this build. First try to build the default project from Host SDK and check if it builds.
Pranava
Pranava
