USB EZ-PD Type-C
hoop4g
New Contributor II
Hello My team and I are looking for Automotive quality USB charging Controller IC among Cypress products
for a replacement opportunity.
Our customer currently uses RICHTEK Technology's RTQ2116-QA, single charging controller chip
comes with Buck boost converter (datasheet : https://www.richtek.com/assets/product_file/RTQ2116C-QA/DSQ2116C-QA-00.pdf ) for 15+ Watt USB charger project.
The part we are looking for shall
-have automotive quality.
-have single chip solution
-be put into use for 15+ W USB-C charger project.
-be replacing Richtek RTQ2116-QA with Buck boost converter.
-have relatively good time for the logistics
the project block diagram (approximate) with the USB charging Controller IC we seek follows:
May I ask if any of Cypress part for the replacement for RICHTEK RTQ2116-QA?
If you could, that would be greatly appreciated.
Thank you for your considerations and help.
Sincerely,
Ben
ShifangZ_26
Hello Ben,
I have reviewed the datasheet you have shared, I would like to recommend CCG7D to you for reference.
CCG7D , this is two port signal chip for Automotive and AEC-Q100 Qualified.  CCG7D is Cypress’ highly integrated dual-port USB Type-C Power Delivery (PD) solution with integrated Buck-Boost controllers. You could get datasheet, reference design (two ports with higher up to 100W on each port), hardware design guidance from local FAE.
Lisa
ShifangZ_26
Hello Ben,
Lisa
